1 - 11 of 11 Posts
I am going from memory on this Ron so I might be incorrect. From your main dash center screen, hit the left arrow on the steering wheel (the unit that controls your dash screen options), then hit the down unit to move to 'performance'. Scroll through those until your center screen comes up with a message something like "0-60, starts timer when you start". Hope that is close enough to get you there :cool:
i tried that. the dic says 0-60
accelerate i have tried and nothing
happens. i stays @ 0-60.
Don't know- I have not had a chance to try it on RedHot yet, have just run across the screen set up.
thanks for clarifying JCobalt! makes sense :cool:
You're very welcome :) I hope that works for everyone. It took me a while to figure it out, and when I finally did, I had the worst take off ever on a terrible road. I recorded a time of 4.9 haha. The timer starts right when you hit the gas, so if you hold down the brake hard and give it a little gas, It'll start. I'm not sure if that's how it's supposed to be, but that's another reason I got such a "slow" time. Maybe it's different when you use it with launch control...? I will try again some day on a better road with a better take off.
When you get to the 0-60 timer screen, click the right arrow button on the right side of the wheel to reset the timer. After doing that, if the car rolls even a few inches, the timer will start running.
S.
And this is what an A6 car will do on a well prepped surface in good air, and I have "rollout" turned off in the Options menu on my Vbox...so that's a real time.
S.
1 - 11 of 11 Posts
