Vendor
Number 13149, Low-Beam Headlamps Inoperative
CONDITION
General Motors has decided that a defect which relates to motor vehicle safety exists in model year 2005-2007 Chevrolet Corvette vehicles. On these vehicles, when the engine is warm, the underhood bussed electrical center (UBEC) housing will expand, causing the headlamp low-beam relay control circuit routed wire to bend slightly. After the wire is repeatedly bent, it can fracture and separate. When this occurs, the low-beam headlamps will not illuminate. As the UBEC housing cools and contracts, the low-beam headlamp function may return. This condition does not affect the high-beam headlamps, marker lamps, turn signals, daytime running lamps or fog lamps. Loss of low beam headlamps when they are required could reduce the driver’s visibility, increasing the risk of a crash.
CORRECTION
Dealers are to install a jumper wire.
VEHICLES INVOLVED
All involved vehicles are identified by Vehicle Identification Number on the Investigate Vehicle History screen in GM Global Warranty Management system. Dealership service personnel should always check this site to confirm vehicle involvement prior to beginning any required inspections and/or repairs. It is important to routinely use this tool to verify eligibility because not all similar vehicles may be involved regardless of description or option content.
