Step up to full length headers and an "X" shaped mid-pipe without the hassles of cutting your old system off. Granatelli’s full length headers and mid-pipe are a direct replacement for the factory short style castings and intermediate mid pipe section, yielding a 26 hp & 21 ft/lbs. increase. Simply remove the stock units and bolt in your polished T-304 Granatelli headers. Best of all they include Granatelli's X shaped mid pipe and they are a direct match up to the factory rear system. No other parts are needed.
Header Style Full Length
Header Material T-304 Stainless Steel
Header Finish Polished
Primary Tube Diameter (in.) 1-3/4 in.
Collector Attachment Slip fit - Stock flange and ball gasket
Merge Collector Built In Yes
Collector Diameter 3.000 in.
Flange Style 1/4 in.
Bolts / Studs Included Yes
Gasket Included Yes
Reducers Included Not Required
Quantity
Sold as a complete System with X-pipe
Notes Granatelli Header Systems are intended and designed
as a factory replacement system from the heads to the
rear "over the axle" components.
THESE PARTS ARE NOT 50 STATE LEGAL AND DO REQUIRE
A CUSTOM TUNE, AS DO ALL LONG TUBE HEADERS SYSTEMS
These Granatelli full-length headers are designed to help improve mileage, horsepower ratings, and throttle response. They feature smooth mandrel bends and are made from durable T-304 stainless steel with machined flanges and precision welds. They include all necessary hardware for installation.
