On the 2014 some folk have had problems with the OEM Sat Nav Flickering and I'd read some had fitted a Garmin or Tom Tom in the Cubby Hole. With The Screen down the Radio still works AOK
so I did my own research as being a UK Member it would prove too expensive to replace the original.
I found the Garmin 61 LMT-D [EURO Map and LMT-S is USA] is about Bang Right for size [See the Pics] I used dual tape along the bottom and just pushed it home. The internal USB Port is not suitable for Power with the Garmin USB lead … that is a Data Lead but further research shows a 3BRPowersports Redband cable Will Supply Power …. mines on Order and will plug into the USB inside the Cubby so will look as Good as the Factory unit.
The LMT- Stands for Free Lifetime Maps and Traffic updates]
I also have on Order the Garmin BC30 Wireless Camera which is 'Taped' into the reverse light wire so works in the same way as the OEM
Having seen some little Sat Navs mounted in the Cubby Hole I thought I'd offer my Solution to the Flickering Sat Nav that looks like 'Factory' …..maybe of Help to any owner whos having a problem
