1 - 11 of 11 Posts
I have a 2015 Stingray. The cigarette lighter is not working. I believe it is a blown fuse. I have the fuse part and diagrams from the manual. I do not see what the fuse number is for the cigarette lighter. What is the fuse number?
I believe the fuse box location is under the hood. I would appreciate.
I need to charge my phone , going on a trip.
thanks.
2014 Arctic White C7 Z51
I think the fuse is not under the hood but in the hatch battery compartment fuse box in which you lift up the carpet in the hatch. Check Fuse FR22A which is a 30 Amp fuse in the rear electrical center.
Also, you can plug your phone into the additional cigarette style power plug outlet inside of the arm rest console as well and also the USB ports inside the arm console also will charge your devices so you have back up options.
Well, I did not know about the power plug outlet in the arm rest console, are you talking about the arm rest console in between the 2 seats? I'll sure give it a look. This vettes is much different than my 2007....
I appreciate. I'll check it out this evening.
As a back-up to the cigarette lighter outlet, here's the inside of the center armrest console that shows two USB Outlets and one Power Outlet like the cigarette outlet. Pardon the Carwash Baggy of quarters. LOL...
PS: You also have USB outlets behind the display screen where you can place something to charge.
Automotive lighting Auto part Automotive fog light
thanks.
If you tried to charge your phone without your C7 running, there would be no power to the accessory outlet up front. That is only 'live' while the engine is running (or for up to 10 minutes after you shut down if you don't open the driver door).
Only the accessory outlet in the trunk is live 24/7, since it is intended to be used for trickle chargers to maintain our C7 main battery.
thanks.
It’s in the trunk area under the mat, left of the battery. It shows the location clearly. I had to replace it on mine.
thanks.
it is the #23 fuse on the under hood fuse box.
277509
2014 C7 Stingray convertible Z51 3LT Torch Red/black int.
I checked the fuses in the front and rear fuseboxes; they were ok. What's your advice regarding my next step? Neither the cigar lighter nor the console outlets are working. I replaced the adapter with a brand new one and the power indicators did not illuminate on either one. Help!
The last post before yours was July, 2020 so you might not receive a response. That said, it seems that you have checked what most of us would have checked as well, so maybe call the dealer and ask the service person the question is there a know issue that they can direct you to check. Good Luck and share your findings once it's figured out!
Azure Rectangle Handwriting Font Grass
Rectangle Font Material property Parallel Diagram
Rectangle Font Parallel Pattern Schematic
Font Rectangle Parallel Map Technical drawing
Rectangle Font Gadget Communication Device Technology
elDavo8899, are you talking about using it when your C7 isn't running? If so, please see post # 5.
1 - 11 of 11 Posts
