My manual says for track events for a Z51, inflate tires to 26psi. Is this correct?
Hmmm, starting out at 50 psi sounds dicey. Most auto tires list 51 psi as max pressure, and a tire that starts at 50 will exceed that after a couple laps.Thanks for the confirmation, but I think it is ironic that I did an HPDE in a competitive brand and they pumped the tires up to 50 psi. Not sure what the difference is. When I first read the 26 psi, I thought it was an error and was concerned that you would lose the tire bead on the rim under hard cornering with reduced pressure. Learned something new.
