1 - 5 of 5 Posts
:( Fuse is good, relay is good and energized, wire going to ac clutch shows open to ground. Unless there is an interlock before it gets to the clutch or interlock in the ground circuit it must be an open clutch. Does anyone have a wiring diagram? I sure hate the thought of having to go to the dealership. Thanks Steve
Steve, it happened to my C7 and the dealership reset the codes, no problem has worked great since. Let us know what the situation was once you get it fixed.
Rick if thats all it is that would be great. I have an OBD2 scanner I wonder if I can reset something myself? Thanks Steve
Moderator
It cannot be reset with the OBD reader. It requires a reflash of the computer.
Sent from my SCH-I535 using Corvette Stingray Forum mobile app
1 - 5 of 5 Posts
