I'm a big fan of Amsoil and have ran it in my CTS V from the engine oil, to the trans, and diff fluid. I haven't had a chance to check my rear diff on this car yet, but GM is well known for underfilling them by a LOT on other high performance models, so they're worth a check. I'm VERY well versed in the auto and manual trans. I have a built 6L90 which is a step up in my other car. Changing the trans fluid regularly in cars that are driven hard is essential in the longevity of these 6Ls and the eDiffs are going to need some regular love too. If I can help with anything, let me know guys!
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......SEO[1]
Maximum Performance SAE 5W-30 Signature Series 100% Synthetic Motor Oil (ASLQT)
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance OE 5W30 Synthetic Motor Oil (OEFQT)
All TEMPS......5W-30
Manual Transmission,TR6070 (7-SPD)......GLS [2]
All TEMPS......
No AMSOIL Product Recommendation
Automatic Transmission,6L80......AF6
Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid (ATL) (ATLQT)
OE Fuel-Efficient Synthetic Automatic Transmission Fluid (OTLQT)
Limited Slip Differential, Rear 3.42 Ratio, Cooler......GLS [3] [4]
All TEMPS......
Limited Slip Differential, Rear 3.42 Ratio......GLS [3] [4]
All TEMPS......
Limited Slip Differential, Rear 2.56 Ratio......GLS [3] [4]
All TEMPS......
All TEMPS......
Limited Slip Differential, Rear 2.73 Ratio......GLS [3] [4]
All TEMPS......
Fluids
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [5]
Clutch Fluid......HBH
AMSOIL Brake Fluid DOT-4 (BF4SN) [6]
[1] Use only engine oil meeting that is GM Dexos1 specification
or equivalent. For track events or competitive driving
use Mobil 1 15W-50 engine oil.
A warning message will display at high oil temperatures
This message displays when the engine oil temperature is
to hot. Stop and allow the vehicle to idle until engine
cools down.
[2] Contact local dealership for fluid specifics.
[3] Use Dexron LS Gear Oil meeting GM Specification 9986290,
GM P/N 88862624.
[4] Synthetic oil is required.
[5] Hydraulic Brake Fluid, DOT 3 GM P/N 19299818
[6] Use DOT 4 Hydraulic Brake Fluid P/N 19299570.
or equivalent.
FILTERS:
Oil Filter
Oil Filter
Cabin Air Filter
NGK PLUGS AND WIRESETS:
GPSERIES PLUG TR6GP
IXIRIDIUM PLUG TR6IX NGK3689
WIRESET WIRESET
WIPER BLADES:
Blade Class Driver Passenger
ExactFit
NeoForm
Winter
CHASSIS LUBRICATION:
0 Fittings, 0 Plugs
CAPACITIES:
Engine, W/ Z51, with filter..........10.2 quarts [1]
Engine, W/O Z51, with filter..........7 quarts [1]
Cooling System, Initial Fill..........11.3 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 6L80 Initial Fill..........6.7 quarts
Manual Transmission, TR6070 (7-SPD)..........7.4 pints [2]
Manual Transmission, TR6070 (7-SPD)..........8.5 pints [3]
Differential, 2.56 Ratio Rear..........5.1 pints [4]
Differential, 3.42 Ratio Rear..........5.1 pints [4]
Differential, 3.42 Ratio, Coo Rear..........5.7 pints [4]
Differential, 2.73 Ratio Rear..........5.7 pints [5]
Differential, 3.42 Ratio Rear..........5.7 pints [5]
Differential, W/ELSD Rear..........0.5 pints [6]
[1] After refill check oil level.
[2] Base, Approximate, fill until level with bottom of fill
plug.
[3] With Z51 performance package Approximate, fill until
level with bottom of fill plug.
[4] Without Z51 performance package standard differential.
[5] With Z51 package electronic limited slip differential.
[6] With Z51 performance package the ELSD Clutch System is
a separate unit from the diferential assembly.
TORQUES:
Oil Drain Plug.....18 ft/lbs
Manual Transmission TR6070 (7-SPD)
Fill Plug 20 ft/lbs
Drain Plug 20 ft/lbs
Engine Oil
Grade 1......SEO[1]
All TEMPS......
All TEMPS......
All TEMPS......
All TEMPS......
All TEMPS......
All TEMPS......
Fluids
Brake Fluid......HB
cools down.
GM P/N 88862624.
or equivalent.
FILTERS:
Oil Filter
Oil Filter
Cabin Air Filter
GPSERIES PLUG TR6GP
WIRESET WIRESET
WIPER BLADES:
ExactFit
NeoForm
Winter
0 Fittings, 0 Plugs
CAPACITIES:
plug.
TORQUES:
Fill Plug 20 ft/lbs
