Hello,
I am running in S mode. So I jumped on it a bit and a message comes up that says something like "transmission performance mode engaged." That was not it, but it is the gist. I am assuming this crisps up the shift points, etc.
In the C6 when you moved to "S" mode this did the same thing. This has now been replaced with "M" which does not shift the car, but engages the paddles.
Question I have is, is there a setting that anyone knows about that can put the car in "performance shift mode" all the time without having to push down the pedal?
Thank you.
