Battery Power Protection
This vehicle has a feature to help prevent the battery from being
drained in case any of the following lamps are left on: vanity mirror
lamps, cargo lamps, reading lamps, or glove box lamps. If any of these
lamps are left on, they will automatically time-out after about
10 minutes. To reset it, all of the above lamps must be turned off or
the ignition turned on.
Exterior Lighting Battery Saver
The exterior lamps turn off about 10 minutes after the ignition is
turned off, if the parking lamps or headlamps have been manually left
on. This protects against draining the battery. To restart the 10-minute
timer, turn the exterior lamp control to the off position and then back to
the parking lamp or headlamp position.
To keep the lamps on for more than 10 minutes, the ignition must be in
the ACC/ACCESSORY or ON/RUN position.
