Banned
The RX dual valve system has been copied, and as part of their marketing they are cutting us down, but the installation and routing of the copycat will not result in the proper evacuation at WOT the RX does...You cannot cut corners and achieve the same results.
And look and see....any similarities? And the RX base is not cheap plastic, it is an OEM quality replacement machined to allow you clock it in any direction, and to add oil after installation just pop the top billet portion off and then replace:
Understanding all the technical aspects cannot be copied like the products can.
