1 - 6 of 6 Posts
What do a string of round blue lights on the top of instrument panel mean on a C7 Z06?
Welcome to our forum Alvin. Do you mean surrounding the tach?
I believe you are referring to the shift timing "lights" or indicators at the top of the dash in TRACK mode. These will fill up and flash yellow to indicate when to shift to the next gear. These are similar to indicators on the actual C7.R racecar... very cool feature. I usually just wind up playing with them when starting from a stop. You will notice that when the engine is colder the lights will indicate time to shift quicker.
This did not answer the question, green , yellow and red are obvious indications of shift points. But at some point the lights flash blue The question was blue lights. Does anybody have the correct answer ?
The lights flash blue at the optimal shift point. Basically saying shift now. When you get into yellow you are adding more revs but not much more power which impacts your times. Red is obvious and even more obvious when you hit the rev limiter. Does that help?
2014 Premier Edition
I'll have to pay more attn.... I've never noticed blue.... just the yellow & red...
1 - 6 of 6 Posts
