1 - 6 of 6 Posts
When I connect my iPhone via Bluetooth the volume is significantly lower than when I attach my iPhone using USB cord. Often I have to turn the volume to 100%. Anybody solved this issue already? Thanks
Check the volume on your phone. If I listen to Pandora in RedHot and my phone's volume is not set at max the volume through the Stingray will be lower than if I was just listening to XM. Once I turn the phone volume setting up, it is the same.
Yeah I found the same thing. Turn up the volume on the phone.
I own a Samsung Android smart phone. I have found with the volume set to maximum on the phone, the volume is about equal to other sources using Bluetooth.
1 - 6 of 6 Posts
