1 - 8 of 8 Posts
I finally got around to switching out the factory Z51 pads & replacing them with the PowerStop Z26 pads, that by all accounts produce way less dust, but are as good in terms of everyday brake performance. Took a couple of hours total & that included dodging around the afternoon thunderstorms & stopping for plenty of tea breaks.
The car has almost 7,700 miles, so I gave the rotors a good scuff with some medium sanding blocks & then a good wash of all compoments to remove as much old OEM brake material as possible. One quick tip for anyone doing a brake pad switch on a C7 that has some miles on it : Once the wheel, the two Caliper pins & Shim are removed, go ahead & push in on the inboard brake pad & pull out on the outboard pad. This will push the pistons back into the caliper & provide enough clearance to insert the new thicker pads. I was able to do it quite easily by hand & it made the new pad install a breeze.
I decided to add a couple of finishing touches to the wheels while I was at it, with new black locking lug nuts & black valve stem caps to finish the look.
Before:
After with new lock nuts & valve caps
All finished, clean up then off to seat new pads in
The hardest part of the job, was honestly trying to drive 10 minutes to cool off the brakes, after the seat-in procedure, without touching the brakes. Sunday morning probably would have been a quieter traffic time to do this. Hope this helps anyone considering doing a brake switch & if anyone wants some Z51 pads with plenty of life left for track use, send me a PM & You can have them. All the best.
West Ham, awesome upgrade and yes the wheel looks great with the black lugs.
Reactions: West Ham Utd
Well done West Ham Utd! Looking really good. I like your mini upgrades!
My Powerstops have been ordered and will be here real soon. Thanks for the suggestions.
Love the new look.
Wow! Those brakes are really good! :D
Yeah D, wait until you've had them on for a couple months then scratch your head and go, "why didn't I change these out early on", I know that's what I did.
Vette's looking good.
I've done about 4-5 change outs now, gettin' pretty good at it. I've got 3 jobs lined up in the next couple weeks for club folks, everyone is seeing the results, they want them now.
Discussion Starter #7
Thanks Norm, sounds like you've got steady work on your hands :)
When I did the brake seat-in procedure, I got on them aggressively for the first five stops to try & remove any residual OEM material that I may have missed during swap out/ cleaning. I did the final set at moderate force & literally just floated my hands on the wheel for the final stop...went straight as an arrow pleased to say. Can't wait to get back out there & put some dust free miles on it.
Super Moderator
Nice job!
1 - 8 of 8 Posts
