Have a 2014 C7 Stingray. When I use REV MATCH- Engine will rev in some gears (2,3, & 4) when I push the clutch in - not even having shifted to a lower gear yet! Does not happen all of the time. This happens more so when going from 3rd gear to 2nd gear. Another quirk is when I place the gear over to second but not in the gear yet it will rev up BEFORE I even have the gear locked in AND the clutch engaged. IS THIS NORMAL?
Some may recall this car had a leaking transmission at 300 miles. GM replaced the whole transmission, which I appreciate. Does this have anything to do with the transmission being replaced meaning something was not set correctly? Car now has 4300 miles.
Appreciate any direction, so I can inform the mechanic.
