1 - 3 of 3 Posts
The stage 1 and stage 2 of the C7 Z06 uses 14.4" brake rotors in the front -- much bigger than the rotors used in the C5 Z06. However, there is also the issues of wheel offset and brake caliper shape to consider, neither of which I have answers to. Sorry I therefore do not have an answer to your question.
However, I would tend to doubt it. If you are asking in regards to whether you should purchase 18" C5Z wheels to use on your C7 Z06, I would get precise measurements, hopefully even try one by putting it one and checking brake system clearance, before buying it. Best of luck.
secrt007agt, welcome aboard, like John posted I would test fit the C5 wheels front and rear wheels prior to purchase.
1 - 3 of 3 Posts
