Purchased a 2014 stingray convertible M7 with 10000. Just had oil changed along with cabin filter and air filter.Is it necessary to change any fluids even though it has low mileage but 7 years old now?Any thoughts? Or things to check out!
Thanks for pointing this out. So many people do not know this is the case. This has always been controversial in the industry so you will get many conflicting points of view. It may seem like strange to take off 'perfectly good tires' at 6 years but better safe that sorry.
Maintenance schedule says to change (flush) brake fluid every 10 years or 150,000 miles. Way longer than I would let it go.
It also says to change (flush) the clutch fluid every 2 years or 30,000 miles. I totally recommend that. Made my clutch feel like brand new. And I would do the brakes at the same time, cause 10/150,000 is too far between.
Jeff - what are you referencing when quoting "tire age"? My 2015 still has plenty of tread.. i know tires age but i have not read anything about these.
I went with the A/S3+ and love them, they have sufficient grip for spirited road driving and they are significantly more comfortable, however I would not recommend them for the track.
If while driving the car it shudders like you hit a patch of rough road, you'll need to get the auto transmission fluid changed. They have to drain, refill, drain, refill and drain and refill again(3 times) in order to get the fluid thoroughly flushed out. There was an issue on the some early ones. I had to have it done on my 2015 with 25,000 miles earlier this year. Not sure if age or mileage caught up to it. I would wait until if/when it does it. Not all do it for some reason. Imho.... As to tires, unless your going to be trying to set a land speed record or racing on a road course, I wouldn't worry about them unless they show signs of age. I still have originals on rear( just about due to change due to wear) and they do not show any sign of aging.
My check engine light illuminated at 38,000 miles, 2015 C7. I have a quality code reader and the code was “generic” transmission temp sensor.
I had the tranny flushed 3 times and that cured it. Once later when I paddle shifted the light illuminated again. No more paddle shifting. $700 for the repair.
At 92,000, yes, change the manual transmission fluid.
I would also recommend changing it, if you have a pop out issue with the shift lever. In my 2016 Stingray, and my 2019 Z06, the shift lever would occasionally pop out of 1st gear on clutch release. After changing the fluid, that problem was significantly diminished.
Related Threads
Stingray Corvette Forum
365.7K posts
16.4K members
Since 2012
We’re a forum community dedicated the Corvette Stingray. Come join the discussion on performance modifications, accessories, purchasing, maintenance and more!
