Hey all|
I noticed that my gauges are running a bit high but they may be normal since I am in Texas and it is a bit warmer here. The larger gauge in the main cluster says 219-220 and the smaller one in the middle is a bit higher. Not sure if that one really works or not. What temps are you all seeing? Have you noticed a pattern of running hot or are any of you close to this temp? Wonder if this is normal? What is normal for the C7?
Thanks for the info!!
Stacey
Stacey
