My floor is 6" thick concrete. I should of explained it better that I was told that was not thick enough for a "2 Post Lift".Quick Jacks are used by a lot of folks. But if you would rather have a four post lift, I am curious what is it about your floor thickness that limits you? I use an older Direct Lift Pro Park 8S on my regular concrete floor (probably 3" to 4" thick) with no problem. It does not bolt into the floor, just sits on it on roughly 11" x 11" feet. Also, my garage is 21' x 21' with a ceiling height of about 10' near the overhead door and about 9'-9" near the front. I keep the lift fairly close to the overhead door and it works fine for a 4' tall car and a 5' tall car. But if you have less than 10' I understand. --Bob
I have a 2015 and have used a quickjack 7000ext for 4 years now. I love it.Due to height & garage floor thickness constraints I'm limited to a only using a scissor lift. Does anyone know of a brand / model number of a home scissor lift that works safely with mid engine vehicles / C8's?
I use the Quick Jack Model 5000 with extensions for the C8. I used the 5000 without extensions to lift my F430 many times.Due to height & garage floor thickness constraints I'm limited to a only using a scissor lift. Does anyone know of a brand / model number of a home scissor lift that works safely with mid engine vehicles / C8's?
Thank you.Welcome to our forum Ray. Great looking C8 and fantastic looking Ferrari F430![]()
