1 - 3 of 3 Posts
The following is an extremely useful post by member jagamajajaran (Jeremy):
If you find yourself trailering your 8th Gen Corvette for some reason, the center of balance is a key safety factor. The graphic I've included shows the center of balance for the 2020 Corvette, which is quite different from the previous generation. Watch the video for a more detailed analysis and some trailering tips.
Click image for larger version  Name:    81714CEA-D5B7-499C-9060-BECE50C45083.jpeg Views:    78 Size:    166.9 KB ID:    146227
P.S. Before you even ask why, I trailered Crushin down to XPEL Dallas after I had completed paint correction and didn't want to pick up any rock chips on the way to Dallas. This trailer is what I will be hauling my 1963 Grand Sport #008 in.
280271
280272
280273
280274
I agree this is very useful information if you are trailering the car. Seems easy to remember that the horizontal component of the center of mass is a few inches ahead of the back edge of the window if you don't have a measuring tape. It also pretty clearly underscores the 40-60 weight distribution. --Bob
Reactions: jsvette
It also shows why, if you don't use the correct lift points, the back of the car falls off a lift.
Reactions: warp ten
1 - 3 of 3 Posts
