Convertible Water Leak
4.5K views 10 replies 11 participants last post by  cutnout
#1 ·
After searching the forum and seeing similar water leaks for some with coupes, I'm wondering if any convertible owners have had a problem? Washed my car yesterday and found a good size puddle of water in the passenger-side weather tech mat, about the size of a paper plate and 1/2" deep at the lowest point. Felt under the dash for a wet spot but didn't find one, but did notice the lower front corner of the passenger window was fogged on the inside of the vehicle. Since I wasn't using the pressure washer I used full stream hose with no sprayer so the car got pretty saturated. Thought I'd reach out to the forum while I do my own investigation. Next step for me will be to have the wife sit in the car with a flashlight and spy while I drench the car. Appreciate any thoughts from vert owners!
Thanks,
Mike
#4 ·
Driven mine through a few monsoons, including tropical storm Cindy, which dropped 3 inches of rain on Indy last week. No leaks.
#5 ·
I'd start with the rubbers, look for splits. Then I'd look for light through the roof itself. Check the window seal. That sounds like a lot of water. The car realigns the windows when you activate the top. There's something in the manual about how to do that. Better yet, make GM do it under warranty.
Hope you're having a good Summer
fltsfshr
#7 ·
No issues here either. Man I hate to hear this and hope you figure it out soon.
#10 ·
Mike, I hope that you locate the leak on your C7 Masterpiece vert ASAP. Like posted it may have something to do with the weather stripping being crimped, a water leak can be a pain in the six until the point of entry is located.
#11 ·
Went through a deluge in Birmingham on the way to a car show in Columbus. The trip included trucks covering us up. No leaks in the '17. I owned two C7 convertibles and one coupe--no leaks in any. Charlie
Reactions: U.S. Marine
