C7 Corvette Stingray Skip Shift Eliminator
Also called CAGS Defeat
Do you hate the 1-4 skip shift installed on the C7 Manual Transmission? This little device will eliminate that annoying issue.
Our corvette skip shift kit will allow you to disable the Computer Aided Gear Selection (CAGS) feature of your C6 Corvette's 7-speed gearbox. This kit comes with the correct connectors, plugs and seals to protect your wiring harness and CAGS solenoid to allow you to re-connect the harness for full CAGS function, if you so desire. This kit is designed for use a C7 Corvette only. Will not fit C5 or C6 Corvette. No permanent modifications are required to install this product.
