HELP! I applied Blackfire Wet Diamond All Finish Paint Protection according to the directions exactly. When I tried to buff it off it left the paint hazy looking. What did I do wrong and how can I fix it??
Thanks Glen, a little disappointed with my first attemptWas the paint clean,
Try buffing it off
Or
dawn dish washing soap
Or 50/50 alcohol/water wipe off
Get the car clean and apply small amt of wet diamond, buff off and there are none better.
I have since experimented with the Blackfire products on my dd and the result was perfect.HELP! I applied Blackfire Wet Diamond All Finish Paint Protection according to the directions exactly. When I tried to buff it off it left the paint hazy looking. What did I do wrong and how can I fix it??
An issue like that is usually a result of applying it too heavily, but other factors can cause it as well.I have since experimented with the Blackfire products on my dd and the result was perfect.
The cause of my troubles could be the plastic or fiberglass fairing on my Harley. I will keep at it and let you guys know.
Thanks for all the input.
Steve
Thanks Rasky, I'll give that a tryAn issue like that is usually a result of applying it too heavily, but other factors can cause it as well.
Take a spray bottle filled with water (distilled if you have it), mist the paint with a little water and lightly buff with a soft MF towel. Quickly follow up with a second dry towel just before the panel is dry. Keep the sections small and swap in a new towel if the dry one becomes too wet. This should clear up any streaking or smearing you have on the paint.
