none - eco, weather and tour are all the same - closed unless you stomp on it....Still don't know what the difference is with the performance exhaust between eco and tour. It is obvious when you turn it to sport. Wish I could keep that sound in tour mode. Does eco do something to the exhaust that actually enhances fuel economy?
RagtopStill don't know what the difference is with the performance exhaust between eco and tour. It is obvious when you turn it to sport. Wish I could keep that sound in tour mode. Does eco do something to the exhaust that actually enhances fuel economy?
look again under vehicle- you have to go a bit into it...it's also in the manual....Ok, I went to 'settings' and there is no option for sound management. Any suggestions?
There are definitely differences between Sport and Track Exhaust Modes. The difference is obvious even when revving the engine from a stop. In my opinion, Track Mode sounds much, much better than Sport. I wish I could skip Sport Mode and, with the NPP slaved to the Mode Selector, switch between Touring and Track Exhaust Modes only.I think there are some differences between sport and track (should = Sound Management Off in the settings). I believe sport mode will close the valves on the highway under light load to minimize droning. That may be why some complain it gets quiet sometimes.
no diff on mine either - base car with automatic....I hear no sound difference between Sport and Track but I have a manual so I never go into V4 mode and get the primary valves to close. What is different is the throttle response which may be why it sounds different in track mode to you.
It's not related to AFM. As stated above, one can hear the difference at idle. At idle, we are all running on all 8 cylinders. Additionally, the throttle is more responsive in Track Mode. Because I prefer manually shifting with the paddles, I don't experience AFM cylinder deactivation.I hear no sound difference between Sport and Track but I have a manual so I never go into V4 mode and get the primary valves to close. What is different is the throttle response which may be why it sounds different in track mode to you.
