Doing this for memory: If you are in Tour mode, use the up/down arrows on the right (3 o'clock) position of the steering wheel. As you move them up or down you will see in the center dash screen "Trip A" and "Trip B" and both will show the related cumulative mpg, or you can again using the same keys see the graphic showing the best and average mpg for the last 50 miles, and finally one of the windows will show estimated miles remaining on the tank of gas and current instantaneous mpg. Hope this helps.
