Is a slight hesitation normal when you push on the gas at cruising speeds? I noticed when I step on the gas just a bit the car hesitates for 1/2 a second then goes. It has plenty of power after the hesitation. Seems to happen no matter what speed I'm at even at 20 MPH and below as well as higher speeds (30, 40 , 50, 70, etc..). I get the same results no matter what mode I'm in (E, T, sport). Anyone else seeing this?
Also I noticed my heated seats barely get warm (both drivers side and passenger). I had them on 'high' this morning for 10 minutes and wasn't sure if they were working. I guess they felt a little (very little) warm but not even sure. I know my other cars will burn your butt and you feel the heat only after 2-3 minutes....
The last observation is the car fogs up really easy. Guessing due to the small cabin. Have to keep the defrost on low.
Still under 100 miles so not sure what is normal and what is not.
Thanks in advance!
-gregb
Thanks in advance!
-gregb
