VIN. 194678S416530.
OK, based on the VIN it is a 1968 convertible with the V8. Also, the stamped number in the last picture of your post indicates that it is a numbers matching motor to the full VIN.
OK I think I have located the code for your engine. The IQ on the stamping means it is a 427ci, 390hp coupled with an automatic transmission.
I believe it is the:
L36 7.0L 427CI V8: 1968-69
L36 427CI V8 Corvette Engine Specs:
Horsepower: 390hp @ 5400 RPM
Torque: 460 lb-ft @ 3600 RPM
Compression Ratio: 10.25:1
Displacement: 427CI (7.0L)
Cylinder Bore: 4.25” (107.95mm)
Stroke: 3.76” (95.50mm)
Discussion Starter · #9 ·
Thanks, then i will by the car. Wasnt sure if it was matchingnumber and a 427.
Best of luck. Let's see pictures once you get it (y)
