1 - 5 of 5 Posts
Reverse Logic is now offering custom stainless steel posts with a 2.5" diameter rubber padded pivoting saddle for ESCO 10498 and 10499 jack stands. Since the pivoting pads are the same diameter as typical Corvette jacking pucks, it's not necessary to use jacking pucks with these jack stands. Minimum height for 10498 and 10499 stands is 13" and 11" respectively. The pads are interchangeable with other jack stand "heads" available through Reverse Logic.
ESCO 10498 Jack Stands
ESCO 10499 Jack Stands
Look very nice, but I'd still want to have a set of pucks in case I need to have the car lifted away from home.
Although not specifically related to Corvettes, this photo of a pivoting block for BMW and MB chassis shows the "ball" on top of the stainless steel post. A small spiral spring fits into a groove in the block and keeps the block in place. Eventually, I plan to offer one additional "head" for the posts that will work with reinforced pinch weld jack points.
1 - 5 of 5 Posts
