full time C7 rear view camera
1234 Views 9 Replies 6 Participants Last post by  red1996lt4
I just installed a rear view camera to augment the rear view mirror on my C7. It is one of the wirerless kind. 7 inch screen and camera is 155deg view. My roll bar limits the view to the rear a bit so I wanted some assist.
Has anyone found a camera with a smaller field of view. Many are 170deg or more, this one was as small as I could find. The difficulty with such a wide view angle is trafic can appear to come up on you very fast and the refresh rates on the screen are also a bit slow.
This was only about $90 and would work great in my tow vehicle but not so great as I had wished for the car.
Looking for one about 110deg.
The screen looks huge in this picture, it is not that big in reality. If I get it a better view angle it will be mounted where the sun visor is.
Car Vehicle Mirror Motor vehicle Hood
Just a warning....blocking front field of view, ala the new monitor is illegal in some states. It will give a reason for a stop.
Reactions: 1
THX
Got one of these on order. camera is 140 deg, found a different one with 120 deg camera, but 4X cost.
Blind spot not my issue. Just blind.
I want to mount the viewer on the visor so as to see everything front and rear and HUD without moving my head.
Automotive lighting Vehicle Automotive tail & brake light Automotive mirror Automotive exterior
I know that the original poster's issue was not a blind spot, but it is worth mentioning that the passenger's mirror in post #4 is not set properly. With properly-set exterior mirrors, most vehicles do not have a blind spot.
Although it has been known for decades to set outside mirrors so you see other cars instead of your own (I personally have known about this since before I was old enough to legally drive) this topic was also even discussed once here on this forum: adjusting mirrors for blindspot
With all three mirrors properly adjusted on my C7, the visibility is far better than, for example, a truck with only two exterior mirrors.
Just remember: you don't need to see your car. You can't crash into yourself. You need to see other vehicles. Set your mirrors to enable you to do this.
  • Helpful
Reactions: 5
Got the unit installed. connected to the visor. it still can fold up. Not everyones cup of tea but works well for what I need. Thx for the input.
Automotive mirror Motor vehicle Automotive design Automotive exterior Rear-view mirror
Better than the big view obstruction you had! I've been running a Vantrue N2 for years, good cam. It has a rearward cam made for Uber drivers mainly to record inside of cabin, but works great on the convertible C7 capturing video to your rear. The nice thing about it is I have it mounted on windshield to the right of and behind rear view mirror, so not blocking any vision out windshield.
***The screen on the Vantrue is pretty much just for aiming he cam properly, NOT for real-time monitoring of blind spots or anything else for that matter, which upon re-reading the OP's post was his intention.
Excellent advice.
