To access the battery is pretty straight forward and does not require any tools. Here are 3 photos showing the sequence in the coupe.
First go to the right rear of the trunk (see red arrow) and gently pull the carpeting slowly away from the wall. [Elegant had the opportunity to discuss this with Harlan's assistant, Phil Minch and he said that the key is not pulling the carpet up, but "straight out/away" -- that pulling it "up" is what is causing some tearing their carpets.]
Next lift up and remove the foam cover over the battery (this has the cut out for the Tow hook screw that is not part of US cars)
Violà, there is the battery
