I am interested in knowing the Ground up difference in inches under the nose between the C7 & C8. I currently own a 2014 C7 and I'm looking at the C8 with the memory lift. With the exception of leaving my garage, scraping hasn't been much of an issue generally . Is the C8 much lower ?
No, the C8 actually has a better approach angle than the C7:
Base / no E60 11.8 degrees
Base with E60 14.2 degrees
Z51 / no E60 = 9.8 degrees
Z51 with E60 = 11.1 degrees
The C7 was 9 degrees.
Reactions: jsvette
