Ive finally lucked out, found a high tech guy who was highly rec from a good friend to install my new V1. First off he was so meticulous i was blown away. The install now that ive watched it first hand was easy. So here it goes
1. Remove all the trunk carpeting snd latch hooks
2. Remove all the covers over the fuse box
Pics are posted below
3 piggy back a fuse to #37 fuse which is on when vehicle is on and off when ignition is off.
4.remove the cover near the sill plate .
5. Remove the visor drivers side and the a cover. This was tricky as ive read in the forum. He disconnected the light to the visor and mic. They clip together so it was no prob at all.
6. Run the hot wire under all the trunk panels by gently pushing them under to conceal the wire, then run the wire near the sill region and connect to the V1 connection kit.
7. Connect the ground wire to one of the bolts near drivers side kick psnel. Sry no pic.
8. Run the included phone wire up thru the aframe cover and tease it under head liner which was easy because ghe visor was removed and there was plenty of room to tease and hode it.
9. Connect to V1 and power up.
WALLAH works perfectly
10. Close up everything and Now i have the perfect install. If you have any questions please feel free to pist or send me a pm. Best of luck. Im so glad its finally done
Thanks Justin from RS1
I
