Have short legs and the position and feel of the clutch pedal was not doing it for me.
Decided that I needed to extend the clutch pedal a bit.
There is an outfit that sells a clutch pedal extension, but it is fixed at 40mm which I thought was going to be too much.
Decided to build my own that would be adjustable in 1/2" increments so I could fine tune it.
The piece I built bolts to the existing clutch pedal after drill 4 holes in the pedal.
The new piece bolts in place and is ajustable though spacers. Once installed the stock pedal cover slips in place.
To go back to stock, unbolt, and put the stock pedal cover back on the original pedal.
A couple of pictures attached to show the unit and the finished install.
I found that a one inch extension was perfect for me.
Lance
Lance
