There are periodic threads on this (and every other automotive, motorcycle, boating, lawn mower, etc.) forum about how often we should change the oil. Answering, or debating, that question is NOT what this thread is about. If you want to discuss that, find one of the other forum threads on that topic. (Here's one recent one: http://www.stingrayforums.com/forum/stingray-corvette-maintenance/11982-oil-life.html )
What this post is about is GM's oil life monitoring (OLM) system. How it was developed, how it works, how reliable it is. The following information was posted a couple of years ago on Bob Is the Oil Guy (BITOG) forum:
Bob Is The Oil Guy | The Internet's Number One Motor Oil Site
Whether you choose to follow the OLM or not is up to you, but I think it's a good idea to understand what it does before you choose to ignore it or follow it.
Note, although the C6 and prior Vette Owner's Manuals always said change after a year if the indicator did not say to change sooner, the C7 integrates time into the equation. Quoting:
"One thing I can touch on and clear up.....the GM oil life monitor operation and my statement that ZDP (or ZDDP as you tend to call it here...most of the API literature just sticks to ZDP so I tend to use that) depletion is the basis for oil deterioration.
My spelling is poor but ZDP stands for zinc dialkyldithiophosphate which , as it sounds, is an anti-wear compound comprised of zinc and phosphorus.
ZDP is dispersed in the oil so as to be at a potential wear site if a surface asperity happens to break thru the oil film thickness causing the dreaded metal-to-metal contact. A molecule of ZDP must be present at that moment to prevent microwelding at the contact site which will cause material transfer, scuffing, scoring, wear and catostrophic failure. The concentration of ZDP in the oil will determine if there is ZDP present to work it's magic. The greater the concentration...the more likely a molecule of ZDP will be there...and vice versa.
By nature, ZDP is sacrifical. As ZDP is "used up" at a wear site to prevent micorwelding the concentration of ZDP decreases.... So...if you measure the ZDP concentration in engine oil in a running engine it will decrease at linear rate based on engine revolutions. Any given engine has a certain number of high potential wear areas where metal-to-metal contact could occur due to reduced film thickness and/or surface asperities....areas such as rubbing element cam followers, distributor gears, rocker arm pivots, push rod tips, etc...... The more of these areas the more ZDP depletion. The more often these features come in contact the greater the ZDP depletion. That is why, generally speaking, ZDP concentration in the oil, for any given engine, will decrease at a fairly linear rate when plotted versus cummulative engine revolutions. The more times it turns the more contact the more chance for wear the greater the depletion. This is as much of a fact as I could quote ever and is really not speculation or anything. It is proven beyond a shadow of a doubt in many studies. That is why it is ONE of the basis for determining oil life remaining and why it is THE basic premis of the GM oil life algorithm. It is only ONE of the things that determines oil life...but it is the one thing that can be tied to engine operation in a linear fashion and estimated very accurately by accumulating engine revolutions via a counter.
The GM engine oil life monitor counts engine revolutions and accumulates the number for the basis of the oil life calculation. It then adds deterioration factors for operating temperature, start up temperature, soak times, ambient, coolant temperature, etc... There are a LOT of factors that "adjust" or affect the slope of the deterioration but the fundamental deterioration is traced back to the ZDP depletion that is inescapable with engine revolutions. The specific rate of ZDP depletion is readily measurable for any given engine so that is the fundamental item that is first calibrated for the oil life algorithm to tailor it specifically to that engine.
You would obviously like to get the oil out of the engine before the ZDP concentration gets so low that it is ineffective at being at the right place at the right time and preventing engine wear so that becomes the long term limit on oil life for that application.
The other things that determine oil life such a acid build up, oxidation, petane insuluables such as silicon from dust/dirt, carbon or soot build up from the EGR in blowby, water contamination, fuel contamination, etc.... are all modeled by the multipliers or deterioration factors that "adjust" the immediate slope of the line defined by the engine revolution counter as those items can be modeled in other ways and accounted for in the immediate slope of the ZDP depletion line.
The algorithm was developed over the course of many years by several lubrication experts at GM Fuels and Lubes, spearheaded by Doctor Shirley Schwartz who holds the patents (with GM) for the algorithm and the oil life monitor. I had the luck of working directly with Dr. Schwartz when the idea of the oil life monitor first progressed from the theoretical/lab stage to real world testing/development/validation. There were fleets of cars operated under all conditions that deteriorate the oil life for any and every reason and , thru oil sampling and detailed analysis of the oil condition, the algorithm was developed, fine tuned and validated to be the most accurate way invented yet to recommend an oil change interval by. As just one example, I have seen cars driven side-by-side on trips, one towing a trailer and one not, for instance, to prove the effectiveness of the oil life monitor in deteriorating the oil at a faster rate just because of the higher load, higher average RPM, higher temps, etc...and it works flawlessly.
The oil life monitor is so effective because: it is customized for that specific vehicle/engine, it takes everything into account that deteriorates the oil, it is ALWAYS working so as to take into account THAT INDIVIDUALS driving schedule, and it tailors the oil change to that schedule and predicts, on an ongoing basis, the oil life remaining so that that specific individual can plan an oil change accordingly. No other system can do this that effectively.
One thing is that I know personally from years of testing and thousands of oil analysis that the oil life algorithm works. There is simply no argument to the contrary. If you don't believe me, fine, but, trust me, it works. It is accurate because it has been calibrated for each specific engine it is installed on and there is considerable testing and validation of the oil life monitor on that specific application. Not something that oil companies or Amsoil do. They generalize....the oil life monitor is very specific for that application. Oil condition sensors in some BMW and Mercedes products are useful, also. They have their limitations, though, as they can be blind to some contaminates and can, themselves, be contaminated by certain markers or constituents of certain engine oils. Oil condition sensors can only react to the specific oil at that moment and they add complexity, cost and another potential item to fail. One other beauty of the GM oil life monitor is that it is all software and does not add any mechanical complexity, mass, wiring or potential failure mechanism.
There is considerable safety factor in the GM oil life monitor. Typically, I would say, there is a 2:1 safety factor in the slope of the ZDP depletion curve....in other words, zero percent oil life per the ZDP depletion is not zero ZDP but twice the concentration of ZDP considered critical for THAT engine to operate under all conditions reliably with no wear. This is always a subject of discussion as to just how low do you want the ZDP to get before the oil is "worn out" if this is the deciding factor for oil life. We would tend to be on the conservative side. If the oil life is counting down on a slope that would recommend a 10K change interval then there is probably 20K oil life before the ZDP is catostrophically depleted....not that you would want to go there...but reason why many people are successful in running those change intervals.
There are entire SAE papers written on the GM oil life monitor and one could write a book on it so it is hard to touch on all aspects of it in a single post. Hopefully we hit the high spots. Realize that a GREAT deal of time, work and energy went into developing the oil life monitor and it has received acclaim from engineering organizations, petroleum organizations, environmental groups all across the board. It is not some widget invented in a week and tacked onto the car."
The OLM system works very well as long as the marketing types leave it alone. In 2008 I ordered a new second generation Cadillac CTS with the 3.6DI engine and GM specified Mobil 1 for this setup and like some its European competitors the OLM was calibrated to allow for many miles (over 20K under good conditions) between oil changes. I had already seen the buildup in the top end of some BMW engines from these extremely long change intervals and decided for this car to change the oil and filter at around the 55-60% life level and then again at around 10% at which point I would reset the OLM. Around 18 months after I bought the car a recall was issued to change the OLM calibration because timing chain tensioners were starting to fail due to oil quality issues. The new calibration resulted in much shorter change intervals and for me the OLM change was now occurring very close to the interval I had been using.
Engineering and the underlying science can provide very accurate information but unfortunately decisions based upon that information are often overridden by individuals with little area specific knowledge, a focus on the short instead of long term, and the basic inability to understand that shallow minds can only process discrete events but the real world is built of interrelated systems.
Very interesting. With a brand new engine type (LT4) is there an additional safety factor built in due to the relatively short experience with that particular engine type? Alternatively, I assume one can glean information from other similar engines, i.e. Racing engines etc. thanks for posting this.
I sent an oil sample to Blackstone at 500 miles, just sent another at 5500 miles (5K on oil and filter) I'll report back when I get the results. IIRC the OLM was in the high 20's at 5k.
For it's lifetime with me, my previous car, 2010 Mini Cooper S, had oil change intervals of 8000 miles. Blackstone always reported the engine oil looked fine, and there was plenty of the additive package left. The MINI OLM was calling for 15,000 miles between changes. When the mechanics changed the timing gears, chain and tensioner, (design flaw and recall), they said the top end looked great. BMW/MINI has since changed to 10,000 mile intervals.
Just another data point.
Discussion Starter #5
Based on the article I posted, it seems there's a large margin for error with all engines. And while an engine is new to us, multiple samples have undergone hundreds of thousands of miles of testing, which gets factored into the OLM algorithms.
And although the specific operating characteristics of the LT4 are new GM has plenty of past experience with engines that aren't that dissimilar from the LT4. A lot of experience from the early attempts at OLM algorithms have long been incorporated into the current iterations. This is why I believe the at introduction extremely long change interval for the Cadillac 3.6DI (or high feature V6 as they were also calling it then) was largely driven by forces outside of engineering. Part of the sales literature stressed the low maintenance/long life oil and compared it to some of its intended European competitors. GM powertrain personnel had too much experience and knowledge to have missed that so badly. In general OLM is very conservative so I generally trust it except for doing an initial oil change for all of my new vehicles prior to 1,000 miles; the 2008 3.6 was clearly an aberration.
I am skeptical it works as wonderfully as claimed. I am a believer in frequent oil changes, but I think the OLM in the C7 has you headed for an oil change way sooner than actually needed. I'd be curious to hear the results of the Blackstone test of 5000 miles, because I'll bet it had a lot more life in it than the 20% the OLM showed. Mine seems to drop almost as fast sitting in the garage as it does when I'm driving it.
Yea. Guess its dependent on all the things said. Its fun watching it go down. Its one of my regular checks. So far I have "obeyed" it with oil changes soon after reaching 20% even though I gotta pay for them now.
