I believe that would be true if the battery is fully charged to its capacity, the track record for new vette batteries is they are not. If the battery is fully charged and assuming it is not defective, a nine day non-use should not be an issue.Honestly, 2 to 3 weeks for any modern car shouldn't be a problem unless you are parking it outside, arming the alarm and the alarm gets triggered a lot like in an airport parking garage. The C7 isn't really any different than a Caddy CTS or a Ford Mustang when it comes to battery drain.
It's not the car or the batteries state of charge at delivery that's the issue, it's the way you use your car that determines the battery condition. It's true of every car sold today, nothing unique about the Corvette (sorry).I believe that would be true if the battery is fully charged to its capacity, the track record for new vette batteries is they are not. If the battery is fully charged and assuming it is not defective, a nine day non-use should not be an issue.
Sorry Mark I don't think so...We will have to agree to disagree on this.It's not the car or the batteries state of charge at delivery that's the issue, it's the way you use your car that determines the battery condition. It's true of every car sold today, nothing unique about the Corvette (sorry).
Transport mode, in conjunction with a float charger, sounds like a good long-term winter storage option, assuming all customized settings are retained.Transport Mode
The Corvette MAY be shipped in transport mode. To remove the car from transport mode, turn ON the four way flasher and place the driver’s foot on the brake AND on the clutch if it is a manual transmission. Press and hold the Start button for approximately 15 seconds. At this point the engine will START, but CONTINUE to hold the start button for approximately 15 seconds. Information will display on the center of the cluster that will indicate when transport mode has been turned OFF. Transport mode can be entered using the same procedure.
Left mine for 16 days while on vacation and it started fine. And I have had a low battery voltage for 9 months! Checked the voltage after a 30 mile trip when I returned (I did that the day after to be sure I wasn't measuring a surface charge) it still read the 12.4 volts it has for 9 months! Meter has been checked. When I got the car, early October it read 12.4 after 1 day after it was charged. When I brought to the dealer some months later to check the rear end lub level I aksed them to check the battery and they said it was fine. Doubt if they pulled the battery (that is a real pain) but have had no problems. If anyone has checked their battery voltage appreciate knowing what you read (I do that at the alternator terminal under the hood a short time after I open the hood and all power items have turned off)Going away for 9 days, don't have a battery tender. Can the battery last that long? Actually, how long can it last?
If you are using a float charger such as the OEM or CTEK 3300 (CTEK makes the OEM version) you will not need to also put your Stingray into 'Transport' mode. It will keep your Stingray at the ready for as long as necessary.Transport mode, in conjunction with a float charger, sounds like a good long-term winter storage option, assuming all customized settings are retained.
Yep, I realize that. Transport mode should make life a bit easier for the float charger over those Winter months, as the battery discharge rate will be minimized and the float charger will cycle less.If you are using a float charger such as the OEM or CTEK 3300 (CTEK makes the OEM version) you will not need to also put your Stingray into 'Transport' mode. It will keep your Stingray at the ready for as long as necessary.
Dude, please...
