1 - 20 of 157 Posts
Started our 4,000 mile trip, with only 850 miles, and a rare tiny squeak in my roof, and then only on really rough road. As we got pounded on I-5/I-40 for hundreds of miles, the intermittent squeak became much more frequent, and we added an rare rattle-clunk when we hit bad pavement. When we had arrived in Santa Fe, it was no longer infrequent. Retracing our steps westward to the Las Vegas area, it had become downright and obnoxiously annoying, as I-40 pavement is a disgrace in spots.
Enter jsvette and his two tools, i.e., applying Griot's rubber dressing on 100% of the roof-to-car structure's rubber mating surfaces, and a dielectic grease for the two, downward facing, front windshield-header aligning pins,,the two rear pins, and the rear roof-attachment "catch hook." [Note, improved/ recommended, specific lubrication grease included below as # 1.] For the next 300 miles, not a peep, and we hit some great "road crevices." Then, the first slight single squeak, then another fifty miles later a creak, then the first rattle-clunk, all with ever-increasing regularity as hundreds and hundreds of more miles passed. You get the pattern. By the end of 750 miles, even the rubber dressing and the dielectic crease had met their match. Meanwhile was reading every one of our forum's posts on this subject, and tens of more posts about how to resolve this same problem on C5's and C6's.
SOLUTION: When parked for the night yesterday, was coincidentally next door to a Home Depot, for many have used the simple, following fix and solved their rattle problems (though almost all of those successes are when this item is combined with rubber mating surface and pin treatments). The solution for us was adding two tiny o-rings!
And, you do not need to remove the top, just undo the two front latches, then the one rear, center latch, and with one person steadying the other side, life up the front end about five inches, slip one o-ring onto onto roof downward-facing pin, then the other pin on the other side of the car. We drove 475 miles today, and not even one tiny, tiny squeak, let alone worse. This package of 10 o-rings costs $2.45 at Home Depot in the plumbing aisle (and is, I am sure, available at many other places).
EDITS/UPDATES:
1) On September 30, 2015, GM released this following service bulletin to do with creaky roof noises:
http://www.stingrayforums.com/forum...lls/14315-roof-creaking-service-bulletin.html
2) Please also see post # 22 as there could be a related noise cause that "travels" up into the roof area and gives one the belief that it is a roof issue. Also, $0.01 solution in that post.
3) Here is another forum thread with more good, related information.
http://www.stingrayforums.com/forum/stingray-corvette-problems-issues/5658-top-rattles-creeks-2.html
And, here, if needed, are, thanks to others' experiences and successes, additonal procedures that have helped Corvette owners solve their roof rattle problems.
Roof Rattle: Other Fixes
1) UPDATED/IMPROVED roof lubrication: "Lubricant of choice is the SUPERLUBE grease as it is teflon particle based and works better than dielectric or white lithium." (GM part # 12371287, Synthetic Libricant, called Super Lube, available at Amazon)
This updated/better information is thanks to "theCorvetteTechnician." Thank you Paul!
2) Re noise was coming from the right front part of the top. After checking every thing was tight, noticed a little scraping on the front right side vertical pin. Loosened up the pin, 17 mm , and adjusted it 180 degrees away; re-tightened.
3) A. Applied Zymol Seal Rubber Conditional to all the soft rubber contact points. As directed, applied generously, let sit for 30 minutes and then wiped off excess.
B. Applied Poorboys World Natural Look Dressing to all the hard plastic pieces where the roof and car met (namely the front pieces that run across the entire width of the window/roof).
4) Tighten rear hatch mechanism (Details thanks to AFVETTE!)
A. Remove top and set it on something to protect the paint.
B. Look at the rear latch assemble and you see a small "silver" colored HOLE in the face of the latch. That's actually a very small HEX nut.
C. Locate the appropriate size HEX Allen wrench.
D. Loosen the HEX nut, I discovered I had to back it almost all the way out, until it was flush with the surface of the latch face itself. I didn't want to go much further for fear of it falling out and loosing it.
E. Initially I needed a big pliers to turn the latch (you'll see it's threaded) and turn in one full turn (it's really the only turn that makes sense).
F. Reseat the HEX nut and reinstall the roof.
5) Applied about 4 layers of electrical tape to the rear pins and just cut the tape off of the tip (ball at the end). I then removed the set screw and turned the closure latch hook one full turn and reset the screw. Then, before I installed the roof, I applied some silicone spray to all of the rubber around the perimeter of the roof.
Wish they made a fixed roof Z06 again. I'm growing really tired of the noise..."rattle-clunk", specifically.
Can't wait to try the o-ring trick. Thanks for posting it, John.
O-rings for the win.... wOOt :cool:
Reactions: Janet C
John, thank you for the info I'm sure it will come in handy in the future. This post is the reason I became a Gold Supporting Member, enough said!!
Reactions: ssscooter66
O-ring trick appears to be a win! Didn't notice any creaks or pops on a 12 mile morning drive. Definitely quieter than it has ever been. Some sharp folks on this forum!
Hope it lasts...
Elegant, a million thanks to you! I was experiencing the roof / A pillar creak. The 7/16 rubber "O" rings attached to the front roof pins were installed and I put some weather strip rubber on the juncture of the drivers side windshield, door and front fender junction, there is a rubber seal along the windshield there, this solved the problem!!!!!! I was seriously considering dumping my beloved Corvette ( my first, and a dream car for me). I now can enjoy my fantastic ride again! You have no idea how much I appreciate your how - to, thanks again.
Discussion Starter · #8 ·
You have hit on another potential noise squeak, e.g., the large, front to back removable rubber trim price, the one that goes into the engine compartment right below that windshield /A pillar, and is a great path to route wires, such as for the Curb Alert, into the cabin from the engine Bay Area. Found/fixed that very squeak on the driver's side just before our big trip.
And no credit to me about the o-rings. Was not my idea. It has worked for 17 years, on many C5's and C6's, and now for C7's.
Well. Elegant, you were kind enough to post this trick along with photos of the product! So, you might as well take credit for helping those who would not have known about it otherwise.
Put o-rings on my roof late yesterday. Short ride home with no apparent popping and creaking. Thanks for posting the idea.
Discussion Starter · #12 ·
If you have tried ALL the suggestions in this thread (for noises travel and your roof frame is metal), try this link, and we hope it works! Especially zero in on the suggestions about tightening fasteners on the rear side the passenger quarter window and/or shim under the rear side of it and then re-tightening, and/or adjusting the rear of the roof's "center clamp" (probably but not exclusively a dealer fix). Good luck!
http://www.stingrayforums.com/forum...ons/2512-list-rattles-how-get-them-fixed.html
Spoke too soon. Still pops...but differently.
I bought and installed the rubber washers this weekend. Creaked and squeaked all the way to Home Depot. I put the washers on in the parking lot and no more creaks or squeaks all the way back home. Thanks for the info.
Z06 Owner, I had a minor rattle in my halo trim soon after getting my car. Turned out to be just a retainer clip or two hadn't seated completely during assembly. If that's your problem, some firm pressure should easily get them in place. I started on one end and just worked across to the other end. Problem solved, no rattles since!
Yes, thank you again John! Appreciate you passing this along with the information and photo. I'm definitely going to give this a try!
thanks for the o ring tip!!! Mine was creaking like crazy....put on the two rings and wow! Silent all the time now. Great tip. Thanks for sharing.
1 - 20 of 157 Posts
