We all have read about how to lower a bit using the bolts.....but we should mention you may be able to raise also.
I had a call this morning from another owner that took his car in to do the 3/4 inch drop and found FROM The factory, just like mine, the rear was already lowered as much as it could be.
So if you plan to navigate thru the slush, check to see if you can get a bit more clearance by checking the bolts.
Lowering/raising how to discussed in build section
