I love the way Track mode exhaust sounds (NPP exhaust), so I always switch to Track mode. However when I start the car, it always starts in Touring mode. Is there any way to start the car other than Touring mode?
I thought there was a way to go to the settings, then exhaust, and set it for 'Track' (always open) that will cause it to stay in that mode regardless which of the 5 modes you have the car set to.I love the way Track mode exhaust sounds (NPP exhaust), so I always switch to Track mode. However when I start the car, it always starts in Touring mode. Is there any way to start the car other than Touring mode?
Thanks. I believe you go into Vehicle Personalization and then to Engine Sound Management, move it from "Auto" to "Off".You are correct jsvette.
Correct and mine is in off position.Thanks. I believe you go into Vehicle Personalization and then to Engine Sound Management, move it from "Auto" to "Off".
Don't have a video but do a YouTube search. I've heard it in person, $1200 for an exhaust system is worth it.Can you send a video so we can hear the NPP sound? Help us make a decision on the option.
Thanks,
I believe "Auto" syncs it with the drive mode you select and will switch between closed and open valves depending on mode, "Off" means it will operate with the valves open all the time.The owners Manual states below. But what does that mean? What is "Engine Sound Management feature"? I was turning it both to auto and off but have no idea what it's supposed to do lol
Driving Mode
Select and the following may be
displayed:
. Engine Sound Management
. Steering
. Suspension
This allows the Engine Sound
Management feature to be turned
on or off.
Select Auto (Mode Selector) or Off.
If nobody knows the answer before I go I will ask at the Museum delivery of RedHot on the 29th.OK I switched it to off and yes, exhaust is louder in all the modes. HOWEVER, each & every time I start the car, it always starts in Tour mode as default. Even if I save all settings and turn the car in another mode, when I restart the car it only starts in Tour mode. Anyway to get the car to start in the mode you turned the car off in?
My car starts in Eco each time but I've been driving in Eco. I have the exhaust set to off so it's loud and it stays that way every start and stop. I'll look at my setting on the drive mode when I'm in the car next.OK I switched it to off and yes, exhaust is louder in all the modes. HOWEVER, each & every time I start the car, it always starts in Tour mode as default. Even if I save all settings and turn the car in another mode, when I restart the car it only starts in Tour mode. Anyway to get the car to start in the mode you turned the car off in?
