Installing calipers
1.7K views 12 replies 6 participants last post by  Stoan
#1 ·
I'm replacing the worn-looking calipers, not going to do it myself. Can I trust any shop to do this? Like BrakeMax or a local shop?
And also, who do you trust to do an oil change?
#2 ·
I would only trust my local shop to do a oil change on my Z51. I just drive it up on the ramp and they do the change. Known the owner since 2004. He would also do my brakes. My 2015 could use all new brakes. The brake dust is unreal and the rotors and getting thin and have some groves. I gotta clean my wheels 3 times a week and i only drive 50 miles a week.
#3 ·
Not sure which engine you have. The wet sump oil change is straight forward. The dry sump is also not hard but I would not trust fast lube type of place. I always change my own. Gives me a chance to look the car over and also look to see how the oil looks. I also send a sample out to a shop at times. But dealers and good shops can do the change with no issue. But check the oil level when you get it back. Only use PF64 Delco filter or High end filter. Never the orange one.
Not sure if you are changing calipers or just pads. Pad changes on these cars are pretty simple. But if you are changing out the calipers I would assume you would change rotors and flex lines also. For this I would make sure you have a good dealer or good high end brake shop.
