What were the costs for each? Does the splitter have an extended bottom under the car? They look great.
recoto, what is the height from the bottom of the splitter to the ground?
$1500 for the three piece set. Ground clearance on side skirt appox. 5.5 inches and 7 1/4 inches on splitter
Is that the cost installed or did you perform the labor? Thx!
wow 7 1/4 on the splitter that's a lot of clearance is that accurate??? mine with spliter and sideskirts is about 5-5 1/4 clearance ,is your car lowered? looks awesome though mine has been hibernating all winter haven't even driven it yet with the new stuff on it.i also have white.
get some xpel door edge guard and alcohol wipe the leading edge of the splitter and apply. Trust me it's a good idea, that front edge takes a lot of abuse.. I have the Lashway too. Have discussed with erik that he should do all the ones he sells, agreed it's a good idea.
Xpel door edge guard on amazon for less than $15. Go slow, it takes all of 30 min to apply. Get a tint shop to put it on, if you are not mechanically inclined.
2014 C7 Z51
Agree with Glen. Get the xpel and get it on that front lip.!. It took about 3 weeks before my first scrap. A little touch up and you can't tell. But didn't like the feeling in my gut.!. Soon after I installed the xpel. At a min, it will give you a little piece of mind that the composite won't fray under a light scrap. Heavy scrap, all bets are off... Worth the $$ and time. Not too hard to install. Prep (cleaning) is most important. Good luck...
