Lingenfelter tests supercharged 6.2L Gen 5 engine
LT1/L86 6.2L GM Gen V direct injection (DI) V8 engine:
Stock long block; full accessory drive; stock exhaust manifolds
Stock fuel injectors and fuel pump
Magnuson TVS1900 supercharger
621 HP @ 6517 RPM & 617 LB-FT @ 3417 RPM
19 degrees timing & 6.8 psi boost at peak power.
Here is the dyno chart of that run:
Is this a peak at what the C7 Z06 might produce?
