Do report this to your dealership so they can keep pressure on GM to know a fix is needed!Yes mine on the drivers side resets where ever it feels like it, not where it started from. I think I will just turn off the reverse tilt.
You are indeed not alone with this issue. Try the idea above, but it is a good idea to report the problem to your dealer / GM. It's probably just a reprogramming / re-flash fixable issue, but GM need to get a feel for the number of people that have it. I am always amazed at these sorts of issues where some people have a problem while other not. Then top that off with some folks reporting that they had their problem show up over time. I don't understand how or why that happens?Anyone else experience this problem?
MrG 69
Soon to be the proud owner of my 3rd Vette, a CGM/Kalahari 7sp Z51 2LT Coupe w NPP, CF Mirrors/Spoiler and BC Roof
** Sent from mobile using Corvette Stingray Forum **
I've taken mine to the dealer twice for this and each time they cannot replicate the issue. I've resaved the settings several times and tried both Fobs and still the same inconsistent operation. Just something I'm going to have to get used to since I have no interest in having them spend weeks on my ride trying to solve such a minor inconvenience. Once I've noticed the mirror didn't return to its location I press the memory seat button again and it returns to its rightful place. I think I can handle that.You are indeed not alone with this issue. Try the idea above, but it is a good idea to report the problem to your dealer / GM. It's probably just a reprogramming / re-flash fixable issue, but GM need to get a feel for the number of people that have it. I am always amazed at these sorts of issues where some people have a problem while other not. Then top that off with some folks reporting that they had their problem show up over time. I don't understand how or why that happens?
Exactly!... Just something I'm going to have to get used to since I have no interest in having them spend weeks on my ride trying to solve such a minor inconvenience... Sent from my SM-N900V using Corvette Stingray Forum mobile app
I've never been able to get any programming to reset them. Guess I'm missing it.memory of veh settings have to be set (an on) before it will come back up...do a search here....it's not broken...
Thanks Marissa, but they do not. Mine is a 2015 and they do change position when in reverse, but do not return to the original set position. Tried with just the drivers, just the passengers, and both. Same resultHi guys,
We have looked into this for the 2014 model, and hope the below information can be of some help:
Hi duckman714,
I hope the below information is of some use to you! Please PM us if you have any further questions:
The passenger and/or driver mirror returns to its original position when the vehicle is shifted out of reverse, or the ignition is off. This feature must be selected through "Vehicle Personalization" on page 5-42 of your 2014 owners manual. If you're in the reverse position and you make any changes to the mirrors, they will not go back to the driving position. This information is also located on page 2-20 for the 2015 model year.
Marissa
Chevrolet Customer Care
Since the suggested solution did not work, sounds like a visit to your dealer is in order.Thanks Marissa, but they do not. Mine is a 2015 and they do change position when in reverse, but do not return to the original set position. Tried with just the drivers, just the passengers, and both. Same result
Sorry to hear that! If you would like to message me, I can try and troubleshoot with you before you head into the dealership.Thanks Marissa, but they do not. Mine is a 2015 and they do change position when in reverse, but do not return to the original set position. Tried with just the drivers, just the passengers, and both. Same result
FCCCVPMan, if I am reading your post correctly in your 08 you programmed the mirrors on the #2 driver memory. If you programmed your mirrors using the equivalent of key fob 1 memory 1, but are carrying key fob 2, that would explain why they don't drop on reverse until you press the #1 button.Can you set the mirrors to go to a set point on rev. I need them to aim down further to allow me to back onto my lift. I had the setting programmed into the #2 setting on my 08' but was hopping you can tell how to aim on rev.
I can't get the mirrors to return to the normal setting unless I push and hold the #1 setting.
A little confusing..FCCCVPMan, if I am reading your post correctly in your 08 you programmed the mirrors on the #2 driver memory. If you programmed your mirrors using the equivalent of key fob 1 memory 1, but are carrying key fob 2, that would explain why they don't drop on reverse until you press the #1 button.
