1 - 14 of 14 Posts
Recently changed the oil in my '16 C7 and when I went to reset the oil monitor it had already reset to 100%. Does this car know when the oil has been changed?
I changed the oil with a warm engine and let it drain overnight. Used Mobile 1 and an OEM filter, not that that would make a change,
Super Moderator
Every model year C7 owner's manual states that the oil life monitor system must be reset manually.
As Vigilance247 indicated, the C7 oil life monitor must be reset manually. On page 228 of your 2016 Owners Manual it provides the detail on the two step process you need to take to reset the monitor.
Must have been gremlins :)
Reactions: jsvette
Discussion Starter #5
I think it was a gremlin. I didn't do anything and it went back to 100%????
OK then, billkahle, we'll go with a gremlin :eek:
Discussion Starter #7
Well, I don't think it was a gremlin. The other day I changed the oil/filter again at 5% oil life. Mobile I and a PH64. The engine was warm and like the last change was allowed to drain over night. After refilling the oil life did not auto reset.
I had to do a manual reset. The issue last year was ME. I'm either losing my mind or just getting very forgetful.
OK guys, this is sorta kinda related. Sounds like several are changing their own oil. I used to on most of my cars. This is my first Vette. I have to ask, do you all have lifts that you use wide enough for the Vette tires to fit on or what? I'm sure to seasoned Corvette veterans this is going to be a stupid question but I have to admit, I like the idea of letting the oil drain overnight and not having to deal with taking it to a dealership for a oil change.
Discussion Starter #10
I use 2 floor jacks. First install hockey pucks on the front tie down points. Lift and place on jack stands. I first drive up on 2"x6" to allow clearance for the floor jacks. Another way would be to make ramps using 2"x8"s or 2"x10"s. Always chock the wheels.
Discussion Starter #11
No chance Budweiser was involved with the one that "reset itself" was there? ;)
After buying the Vette I can't afford Budweiser.
Reactions: stevec
Change my own, let it sit thru a lunch break, usually dripless by then.
277997
277998
1 - 14 of 14 Posts
