Can anyone here share what their typical oil pressure readings are. Mine run about 30 psi and have even seen it as low as about 26. Is this normal? Seems kinda low to me..
Thank you, lots of new stuff to get used to.Yes, that is perfectly normal. My 2014 5.7L Silverado (same engine architecture) runs in the same range. It's the difference in oil galleys and sensor pickup point that makes it so different than what you are used to.
A lot of these do that including mine, I have a feeling they all do it but a lot of people dont have the track dash on and watch the oil pressure gauge when warming up. The oil pressure just jumps around (not RPM related) before it warms up all the way. Not sure why exactly but my guess its the ECM self testing the electronic oil pressure control to make sure it works before its warmed fully.I have another issue - oil pressure fluctuation, Z-51, Dry Sump:
When the car is warming up, after driving a mile or two, I get a momentary rise in oil pressure of up to 15 psi AFTER shifting into the next higher gear. I might go to 2000-2500 rpm in first (at normal acceleration levels, in other traffic), then I shift into second, and right after the clutch engages the oil pressure surges from a few pounds to perhaps over 15 psi (as high as 60 psi a few times) and then drops back down to normal, which is between 35-45 psi at normal lower engine RPM's. Same with the next upshift. It barely does it, if at all, after ten or fifteen miles of driving.
It will do this after driving 15 miles (oil temp rising, maybe at 150-160 degrees), if I park to buy a few items in a store, then come back out and start up again.
The oil level is normal, so the oil shouldn't foam.
The voltage barely fluctuates, if at all, while shifting. Some slight voltage fluctuation is usually present.
I have not been able to make this happen by playing with the throttle, but I haven't tried that hard.
Anyone else have this problem? Or know why this happens?
Someone may have a better answer, but my C6 ZO6 does this also. I think it is temperature driven, as the oil reaches operating temperature the RPM vs Oil pressure flattens.I have another issue - oil pressure fluctuation, Z-51, Dry Sump:
My Z51 is the same, and I recalled GM talked about the C7 having a variable displacement pump. This was in an early press release, "The LT1 oiling system – including oil-spray piston cooling – was also optimized for improved performance. It is driven by a new, variable-displacement oil pump that enables more efficient oil delivery, per the engine’s operating conditions. Its dual-pressure control enables operation at a very efficient oil pressure at lower rpm coordinated with AFM and delivers higher pressure at higher engine speeds to provide a more robust lube system for aggressive engine operation."Can anyone here share what their typical oil pressure readings are. Mine run about 30 psi and have even seen it as low as about 26. Is this normal? Seems kinda low to me..
Actually the lower pressure is because they moved the oil pressure sender to the front of the engine and it reads oil pressure after it goes through the engine as opposed to the 'old' LS engines with the sender in the rear that came off the oil pump before it went through the crank/cam/lifter galleys. GM release said 7-10psi lower than LS engines.My Z51 is the same, and I recalled GM talked about the C7 having a variable displacement pump. This was in an early press release, "The LT1 oiling system – including oil-spray piston cooling – was also optimized for improved performance. It is driven by a new, variable-displacement oil pump that enables more efficient oil delivery, per the engine’s operating conditions. Its dual-pressure control enables operation at a very efficient oil pressure at lower rpm coordinated with AFM and delivers higher pressure at higher engine speeds to provide a more robust lube system for aggressive engine operation."
Explains the lower pressures. It's more than the oil viscoity!
That's the gauge initiation routine, oil pressure doesn't start reading for a few seconds but other things are initializing too so it's normal. Threw me a bit when I changed the oil since that's my indicator the car is pumping the oil I just poured in.My oil pressure pocket gauge has a delay before it starts to rise when starting. Is the location of the sender the reason, or is the update of the reading delayed by instrumentation initialization? It does not make any difference if the engine is cold or hot when starting. I have not compared to the readings in Touring or Track mode because I always drive in Sport mode.
