I have automatic transmission. I know in manual you can go 1st to 4th. Can you skip gears with paddle shifting? I haven't found a way but maybe there's a way?
You can quickly hit the paddle multiple times and if it is within the normal range it will allow it, otherwise it will deny the shift.I have automatic transmission. I know in manual you can go 1st to 4th. Can you skip gears with paddle shifting? I haven't found a way but maybe there's a way?
This is very correct.... if it reacts any way like our CTS Coupe. It won't let you do to much that may screw up the tranny. I've messed up my paddle shifting myself and thank goodness it didn't do what I attempted or I may have been in deep s---!You can quickly hit the paddle multiple times and if it is within the normal range it will allow it, otherwise it will deny the shift.
