2014 C7 Corvette: Has anyone experienced a battery drain caused by the push button start switch?
When starting the car, the push button will sometimes not engage the starter right away and has to be pressed a second time to start the engine.
Note: This issue showed up when original battery was replaced and battery would drain in a short period of time, sometimes overnight! Had new battery checked and it is good.
Had it to the area Chevy dealer and they suspected bent connector plates at the battery and thought the issue was solved. Battery drained within 5 days. Took back to dealer and they said something may be waking up a module when the car is not running causing the battery drain but could not pinpoint the issue.
I was just wondering since the push button wakes up everything when starting the car, maybe if it is bad, it may be the issue?? Help!
