"For those having shifting issues on the manual transmission, have your dealers tech pull up #PI1276A. Was issued for 2014 manual transmissions. Turns out the shifter has to be aligned in neutral position. If it is not perfect from the factory, you will have issues."
This was submitted by tjwest after his car was repaired for shifting issues. Thanks tj!
I found this video that shows the problem. This happens to be a 2015 Z06 car so there must still be some problems to be squared away.
