Not sure this makes sense where unlike a manual you're not lifting off the clutch or gas, with the auto you just keep your foot into it and hit the paddle shifter moving up the gears......Does the paddle shifting auto in the C7 have "rev matching"? thanks!
Simple answer is to not wear out the clutch.Okay, so let me ask the following: other than on the track where you sometimes don't want a downshift to slightly slow your forward momentum, why would anyone care if the C7 has rev matching at all?
I grew up in an extremely mountainous area, and I would intentionally use downshifts to help slow the speed of the vehicle. I never blipped the throttle because I WANTED the engine to help slow the vehicle. Also, I know this did no damage to the engine or transmission because an old GMC S-15 pickup went through this downshift-to-help-save-some-brakes treatment for over 230,000 miles and was still going stong when my sister totaled it during a rain. Also, for every other manual transmission vehicle I have driven, I drove it that way, and never had a problem.
So, my question is, other than in a high performance scenario where someone needs to downshift and still not lose any forward momentum, why is rev matching needed?
Okay, that makes sense, but how much wear are we really talking about here? Why did I get by all those years in really mountainous areas and never have clutch problems? GMC vehicles are built like tanks?Simple answer is to not wear out the clutch.
Best example I can recall is my old Toyota 4x4. Original clutch lasted 160k miles. Most folks were getting half that. I did plenty of downshifting and drove it hard (well, as hard as you can for the old 22R-E that was in it) but I did blip the throttle on downshifts to match RPMs as close as possible.Okay, that makes sense, but how much wear are we really talking about here? Why did I get by all those years in really mountainous areas and never have clutch problems? GMC vehicles are built like tanks?
Edit... Hum, now that I think about it, maybe I did have to have the clutch replaced on that old S-15, but just thought of it at the time as normal maintenance...
Thanks Mark, I think you probably hit it right........while I rarely drive my SMG M6 hard enough to really need the rev-matching feature, I sure enjoy the sensation of being a better driver than I am.......and while I've never really been a Corvette sort of guy (though I never doubted their capability) I will be putting in my order for a LRG Z51 in a week or so. Will be selling my M6 and my beloved NSX for the C7, hope I'm not making a mistake. Enjoying the forum for sure!Don't overthink it guys (and gals), the reason for rev matching has nothing to do with wear and tear, it's to prevent the rear of the car from becoming unsettled as it down shifts. It's why a performance driver learns how to heel-toe and why motorcycles have slipper clutches.
And yes, the auto on the C7 rev matches on manual (paddle) downshifts. If you watch the tach as you downshift you will see a blue line appear? That's the RPM the computer used to "match". It doesn't do it in full auto mode. Also remember the OP asked about the auto trans, not the manual. However, the same logic holds true for the rev matching on the manual, it's not for wear and tear, it's purely a performance issue.
