Do they do this to every car? I cannot imagine that because I have so many body panel issues I am noticing now?????? I just noticed my passenger door does not shut flush when closed, it is like 2 mm out as if i did not slam the door hard enough?Based on my NCM tour: In addition to the checks that are done all along the production route, the finished Stingray is pulled into an area with bright lights to go over the entire body and check the paint as well as fit and finish. Next the car is driven over large rumble strips and driven onto a dyno. There it is hooked up and run through a number of rpm run ups, braking, etc. I think I remember several hundred electronic tests were run while on the dyno. While running the tests the car is run up to 70 mph. If any of the electronic tests don't pass the car is pulled and sent for repair. After that the car is run into a high pressure 360 degree wash to check for leaks. If all passes then it is taken out for a test track run. Cars are going for a NCM delivery are then put in a hold for 10 to 14 days. This period is to hopefully insure any issue with a part in a specific batch on that car surfaces from other tests that are run. If there is a problem it is replaced before the car is released for Museum delivery to the owner. Cars going to the dealer have a natural 'hold' as a result of the transportation to the respective dealer and again, if there is a problem, the part is replaced at the dealer or the car is not released until a replacement part arrives.
Every car coming off the line when I was there went through the same procedure including the pre-production Verts that were just beginning to be built but not released to the public at the time.Do they do this to every car? I cannot imagine that because I have so many body panel issues I am noticing now?????? I just noticed my passenger door does not shut flush when closed, it is like 2 mm out as if i did not slam the door hard enough?![]()
That is the same thing we saw, every car goes through the process, none are exempt. I too noticed that the rear of both doors on our museum delivered car are not perfectly flush with the rear quarter panels and I didn't notice it until I got home so I believe it's either by design or something takes a set after a while that causes the gap. I haven't decided if it's enough to ask the dealer to take a look, I hate having a dealership mechanic wrench on my car for something so minor. It may be a simple latch adjustment I can do myself. It's interesting because I saw the QC guys using feeler gauges on each and every car going through final QC on the line which leads me to believe its by design.Every car coming off the line when I was there went through the same procedure including the pre-production Verts that were just beginning to be built but not released to the public at the time.
The body panels on the C7 are not structural, they are hung/attached to the chassis. You could remove all the body panels on the C7 and it would have no effect on it's structural integrity.Could it be that the body is not solid enough to handle the car's torque?
I remember when I had a 2000 Camaro SS and it began to have this issue after several launches and a few races at the Las Vegas track. I then installed a stabilizer bar in the engine compartment and on the bottom sides to provide the solid strength it needed to prevent these issues.
Does anyone know if the C7 has the solid requirements for launch and racing rigidity?
No, the dealer did not fix my panel issue after having my car for 4 days, he said there are no adjustment bolts. I am now exploring my next move?Steve, I was wondering about that with the problem you've had with your Vette. Did the dealer square away your situation?
Steve, it reads like the dealer had it for four days and didn't touch it, time to move up the chain of command Chevrolet Customer Care. Hope all is resolved in this matter.No, the dealer did not fix my panel issue after having my car for 4 days, he said there are no adjustment bolts. I am now exploring my next move?
I am on the phone with a GM specialist right now who has taken my information down and will be contacting the dealer and investigate. I asked for her name which is Selina, I asked her last name and she says they cannot give that information out for safety reasons. WTF?Steve, it reads like the dealer had it for four days and didn't touch it, time to move up the chain of command Chevrolet Customer Care. Hope all is resolved in this matter.
The fact she would not provide you with her last name is normal and no reason to get exercised smajicek. Sometimes they will when pressed provide a reference number. I presume you asked her to note your information down in your file. You have her first name, the number you called and the time and date of your call as documentation should you need it.I am on the phone with a GM specialist right now who has taken my information down and will be contacting the dealer and investigate. I asked for her name which is Selina, I asked her last name and she says they cannot give that information out for safety reasons. WTF?
Steve, sections 13.1-13.3 of your Owners Manual sets forth the progressive steps toward resolution. Sorry your local dealer was a total failure. Good luck getting your panel fixed quickly!No, the dealer did not fix my panel issue after having my car for 4 days, he said there are no adjustment bolts. I am now exploring my next move?
It is a dyno set of rollers, that takes the car up to 80 MPH and back to zero in 30 seconds, and tests 70 different things during that short time period.My vette only had 2 kilometres on it when I picked it up from the dealership. There is no way they ran it on a dyno.
thanks John, I am on step 2 of 3 spoke with the GM Specialist who will be contacting the dealer and created a case number for me. here are some more new body panels in the rear not right and I want them fixed....Steve, sections 13.1-13.3 of your Owners Manual sets forth the progressive steps toward resolution. Sorry your local dealer was a total failure. Good luck getting your panel fixed quickly!
My rear panels have the exact same deformity. Dealer could not adjust so they are going to replace.thanks John, I am on step 2 of 3 spoke with the GM Specialist who will be contacting the dealer and created a case number for me. here are some more new body panels in the rear not right and I want them fixed....
View attachment 9763 View attachment 9764 View attachment 9765
