1 - 20 of 35 Posts
Radiator is leaking. Service has ordered a replacement. I noticed anti freeze spots under left front of car. Service tech says its a bad core.
Yours is the fourth report of a bad radiator I've seen. We have had at least one other member on site that had the same issue. I wonder if GM has received a batch of bad radiators from its supplier?
A friend here in STL has his leaking as well. He has a new convertible. Less than 1000 miles.
Cyber Grey, Born Oct. 29, 2LT, Nav, Auto, Z51 Spoiler. Used Xpel Bra.
Just had my radiator replaced this morning. A leak was noticed by a service tech while doing a oil change. It came off the build line Oct 7.
Which dealership did you use, Raiderh20boy? Did you go to Rio Vista or somewhere else?
Discussion Starter · #6 ·
I just talked with my friend that has a new conv. and he has a transmission coolant line and fitting being replaced that connected to the radiator that was leaking. What the deal with these leaks? I am sure there are others out there that have not noticed the problem. I am going to my dealers tomorrow to be sure it's the radiator and not the transmission coolant lines. Leak seems to be in the same location....putting in my radiator tomorrow;-(
Jim; While your there for this replacement ask if there is any kind of a TSB for this issue yet. It appears that there is an increasing number of owners reporting this problem. I suspect as spring weather arrives there will be even more reports of this problem reported.
Discussion Starter · #9 ·
Ok Chip I will...going back this week for a wheel balance problem. I will ask then.
Noticed some fluid in my driveway as I closed the garage door today, seemed like two streams, thought it might be the AC unit giving off accumulated ice.
I'll look closer tonight as I leave for an appointment.
Thanks for the heads up
Born Dec 11, 2013, delivered Jan 31, 2014, cyber grey 3LT coupe, awesome!!!!!!
Had my radiator replaced two weeks after delivery. Car arrived 10/15/2013 Vin# 3383. Noticed spotting in garage.Dealer replaced said failed pressure test leak on lower right side.
looks like I have the same here... my vin 6376. Noticed a dime sized spot a couple weeks back, this morning noticed a few more, jacked up the car looks like lower passengers side is leaking a smidge. Got to got to make an appointment with a dealer now.....:mad:
Guys: Please check and see if there is a TSB or PI for this problem when you take your car in for replacement radiator. The number of owners reporting this problem is growing at an alarming rate, and I feel like GM has to know there is a problem by now.
1 - 20 of 35 Posts
